Question about Lexicon Alpha Personal Recording Studio
Cubase 5 i/o settings is ok but hear no sound from installed plugins and not respond midi connectivity for hearing sounds section.At the transport seems like signal getin through but no sound!!The system is Athlon x2 2,20ghz 4gb ddr2 ram and usb interface Lexicon Alpha and Vista X64 Ultimate.It is possible to make an update at drivers for Alpha usb module??
SOURCE:
  • 5603 Answers
SOURCE: Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Posted on Aug 24, 2009
  • 5603 Answers
SOURCE: im having a problem with hearing my b-1 studio
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Posted on Nov 03, 2010
  • 5603 Answers
SOURCE: Hi, I bought a Lexicon Alpha
I suspect the problem is with the software setup in your PC. Verify all the options and also verify that the AUDIO system is assigned as stereo and assigned to the Lexicon for both in and out... Also check any "PAN" control settings. There is a possibilty that the Alpha has a dead channel...
Try putting a stereo signal into the 1/4 inch jacks and see if both record... if NOT then take it for repair under warranty... I had a Lexicon Omega that had a problem myself... warranty repair...
Posted on Jan 11, 2011
  • 5603 Answers
SOURCE: Just bought a lexicon alpha. I installed
First, I could NOT find an MXL99 microphone... IF you have an MXL990 microphone, you can STOP trying to have the Alpha read it because it won't !!! The MXL990 is a condenser mic and requires that Phantom power be supplied to it and the Alpha does NOT have Phantom power.
I have found a common problem on the audio interface inout is having to GO INTO the windows Sounds and Devices and verifying that under the VOICE tab, checking that the inout device is listed AND then checking the volume is turned up in that window... It seems like you have to verify everything and tweek a dozen places to get everything right to work. Having to look under the "VOICE" tab is not a good description of where the Alpha input control should be... so anyway, check that as well as it is not MUTED in that window. With Adobe Audition, make sure you set under the options, the "metering" to monitor the input recording level.
Posted on Jan 15, 2011
  • 5603 Answers
SOURCE: i have Lexicon IONIX U22,
Check the power adapter for the Lexicon. The USB may not be supplying enough without the adapter to run this.
Posted on Jul 04, 2011
Open Questions:
Lexicon Alpha Personal Recording Studio Logo
Top Lexicon Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
