Sometimes my iPhone will over heat and I wont be doing much but listening to music, suddenly it'll say 'No Service' where it shows my WiFi and then a little while after it'll shut down and stay on the apple logo for a while then it'll turn back on with a 'connect to iTunes' I do connect it to iTunes but it doesn't do anything! Can someone please help me? [Please don't tell me I should get it fixed at an apple store for a solution.]
SOURCE: My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: iphone wont turn back on after cydia download
Open itunes. with your phone off hold home button and plug phone into computer and hold until itunes sees the phone. You can restore then. The phone will be in dfu mode. If that doesn't do it connect the phone hold home and power for 6 secs. then release the power button while holding the home until itunes sees phone. Restore and use your phone again...
SOURCE: iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
SOURCE: iphone wont turn on
if your battery got so low that it didn;t supply power to the phone, it probably relocked the iPhone.
It sounds like you either having a low charge from the computer or you need to buy a good a/c charger and charge your phone with it and see if it comes back.
But it's definitely battery related
SOURCE: my iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
After this you'll need to jailbreak it too....
Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
