SOURCE: 2006 Azera Difficult starting was engine is warmed up
It is the trans ponder. if they replace the chips its better because the problem is in the the car key chips , they should the same brand .
SOURCE: 2002 1.3 accent. Only done this once before in 9
hi there i have had loads of problems with these accents fault is with your crank sensor.
Testimonial: "100% correct! Thanks"
SOURCE: changed timing belt,crank sensor,timing marks dead
there could be to problems same happend to me
1.you might have a problem with your alternator go get it checked at auto zone or something
2.theres a magnet next to the throttle boddy sometimes it overheats and shuts the car completley off so u might to get a new one!!
SOURCE: After a short run ignition is lost on restart.
Your ignition module is out since it's hard to re-start right after engine has warmed up. This module is located inside the distributor and two screws hold it on. A very easy fix.
SOURCE: 2006 sonata doesn't start at
Check your battery terminals. Take the cables off you battery and clean with a mild solution of baking soda and water. Also check the ground cable and make sure it is attached securely. I had a truck that did the same thing and it was a corrosion problem.
