Avanti ER20AW-1 Electric Kitchen Range Logo
Anonymous Posted on Jul 06, 2013
Heating element The baking element went bad and I need to replace it. I am unsure how to get to the hidden baking element.
My Electrolux double oven goes from "bake" to "warm oven " after about 1 hour. I try to use the other oven and it will go start to "warm oven"
is the bake element getting hot?when you put the oven on bake both the broil and bake elements come on,if just the broil element is getting hot it might take it an hour to heat up.you might just have a bad bake element,if the bake element isn't hidden does is turn red? if not it's not getting hot.
Oven heats slowly, bake element has been replaced
Yes, it is very possible that when the bake element burned out, it may have shorted out to the case of the oven, and burned up the relay on the control board. If you have a voltmeter (and feel comfortable in doing this), remove the back of the oven, and measure the voltage across the bake elements when you set the oven to some bake temperature. Be careful, you are dealing with 240 volts AC here! IF you don't have any voltage anywhere near 240 V while on bake, then you probably have a bad electronic oven control. If you have just 120 volts, then check your voltage at your power cord or (better) at the junction box at the back of the range. You should have 120 volts from the center (white or green) wire to either the red or black wire; and 240 volts from the red to the black wire. Now IF you have 240 volts across the terminals of the bake element, then you may have gotten the wrong bake element (wrong wattage - lower watts than the original). Maybe you ordered the wrong one, or maybe they put the wrong one in the box.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 • Ovens
How to replace the lower, hidden bake element in the lower oven of an Electrolux Icon oven
You need a 1/4 or 1/16 mm. to take it out, they always have a simgle plug.
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
4helpful
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Oven won't come to temperature
sounds like you may have a bad bake element. can you see hte bottom bake element??? if not you can lift the oven bottom to reveal the "hidden bake element". eitehr way, the elemnet usually looks bad upon closer inspection. theres aburn hole in it or its completly broken. perhapseven a white powder plume from where the element went bad. if thats the case, its an easey enough partot replace yourself. 2 screws and2 wires.POWER MUST BE TURNED OFF FIRST LIVE WIRES AT ALL TIMES TO BACK OF ELEMENT!!!!!!!!!!!!!
3helpful
How to replace a fan bake oven hidden element
Before attempting any repairs, make sure the power is turned off! If you are unsure or not confident, please call a service technician.
The element is behind a cover that is held in place either by screws or clips. Once the cover is removed, the element will be visible. The element will be screwed in place by a number of screws on the base plate and around the element itself. After removing the screws, pull the element fron the rear of the oven. the wires should be attached to the element via lugs. The lugs need to be unattached from the element. Before removing the wiring, take note of the connections so that reinstallation can be carried out.
Top Avanti Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
