I hit a hard bump in a parking lot with my pride scooter. When I pressed forward the unit moved , stopped and emitted smoke from the control board (pcb) in the tiller. The unit CB was not popped. Several resistors on the pcb are now black. do you know where I can get a board or a schematic? Thanks, Ralph
SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
SOURCE: my pride go go elite scooter dies
it is either a bad throttle pot, or the set screw that holds the thumb forward/reverse paddle is loose causing the speed to slip, allen wrench to tighten if setscrew is problem
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
SOURCE: Spare Batteries for Pride Revo Scooter
You can't do it with a car battery charger as it takes a 24 volt charger and it has to be designed to charge the sealed batteries that go in scooters and power chairs or you will blow the batteries up!
Order another battery case and swap the battery packs on the scooter with the spare pack once a week. Sealed batteries do not store well and need to be charged fully at least once a month to ensure long life. These batteries aren't cheap, and it's worth keeping them in shape.
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
