As mentioned in the title; there is no sound coming from the right speaker, but the left is working normally.
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
SOURCE: front left speaker is louder than the right one
JUST ADJUST THE BALANCE IN THE VOLUME CONTROL, YOU CAN FIND IT IN THE CONTROL PANEL OR AN ICON AT THE BOTTOM RIGHT OF YOUR SCREEN, THE RIGHT NEXT TO THE CLOCK.. PLEASE VOTE FOR MY POST
SOURCE: Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
SOURCE: my right speaker does not work, but left does
tell me how to connect vose speakers to my desktop computor
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
