Drills Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't take a charge. batteries are good
Opened case, removed batteries and charged them separately. When assembled unit won't take a charge .
  • 2 more comments
  • hrbbarh Mar 27, 2009
    Plugging drill into charger will not recharge it. Removing batteries from drill and attaching them directly to charger and the batteries take a charge.So I think yhe problem is within the circuit in the drill itself.Is a schematic for the internal electronics available?
    Hrbyfxit.
  • Anonymous May 11, 2010
    Details of the models would be helpful
  • Jim London
    Jim London May 11, 2010
    Hi, Seriously dude, would like to help you but you are not helping me. I have no idea which drill you have. Troubleshooting long distance is difficult and more so with you making me guess. It's like I ask you, my car doesn't work do you have a manual? The more information you give me the better, like a model number of the drill and charger. If you charge the batteries by themselves do they work in the drill? Info please!
  • Jim London
    Hi, I am sorry I can't figure out what you are trying to say. The batteries charge in the charger and the charger indicates they are charged, but the drill does not operate with either battery. Is is correct?
stephen Adams
Level 3:
  • Master 2,219 Answers
  • Posted on Apr 11, 2010
stephen Adams
Master
Level 3:
Answers
2219
Questions
0
Helped
355158
Points
22262
Why?
The charger is designed to charge all the batteries at once. The only suggestion is that you measure the voltage of each battery to see if it has charged.
It one or more are dead, this why the charger cannot charge them.
Replaced batteries in a Black & Decker Cm1836 Cordless electric lawn mower. Worked great for two months but now batteries are already not holding a charge. They show 36VDC until you put a draw on them then...
This unit has 3 separate 12v SLA batteries, yes(?).
Remove or disconnect the batteries and try charging each battery separately with a 12v automobile battery charger.
I suspect one or more of the batteries has not taken a sufficient charge and is "fooling" the charger that came with the mower.
Once you have separately charged all three batteries, reinstall and try.
Ir105 canon model error code E000068-0000
Hi Mohammad.
There is an error in the high-voltage output to the separation charging assembly.
An error (leakage) to the high-voltage output to the separation charging assembly is detected.
Check if the transfer charging assembly and separation charging assembly are mounted properly. - Check if the connector (J722, J723, J730, J734) of the HV-DC PCB and the connector (J741, J742) of the HV-AC PCB are mounted properly. - Replace the HV-AC PCB. - Replace the separation charging assembly. - Replace the pre-transfer charging assembly. Canon iR105 Error Codes List page 3 from 9
How to open APC UPB10 battery pack to change the chargeable battery?
1. Remove front cover by sliding front panel down.
2. Install 4 new AAA (LR03) batteries (sold separately) and replace cover.
3. Turn unit on by sliding ON/OFF switch towards USB port. LED will
illuminate.
4. Plug USB charging cable (sold separately) into the Emergency Power Pack's USB port.
5. Plug the other end into your mobile device. (Make sure you do this last, as a few devices will not recognize the charge otherwise). Your device is now being charged
5helpful
2answers
My LG RD 6100 is showing charging but it is not actually charging.After removing charger it is showing that recharge the battery
It is best to get the charger checked with another phone as to confirm the case. In some cases the low regulation within the phone can efffect the charging circuit.
Also cross check the battery as if the battery is weak or had been not charged initially properly then it seems a suspect.
Dec 29, 2011 • Cell Phones
My asus notebook won't charge i just bought last five days ago, and now it won't charge.. i tried to remove the battery and attach the adapter, but it still doesn't open..
if it wont charge it most likely has a bad battery...if you just bought it, I would suggest returning it for a replacement. Make the vendor or manufacturer make good on their product.
2answers
How to charge battery?
In most cases you use your cigarette lighter that came with your unit to charge the battery. I myself have a home ac to dc converter to charge mine with.
2helpful
My Tungsten E2 is not charging. It has been with me for almost 4 years now. What seems to be the problem? This is not the first time though I encountered the same problem. 3 years ago I encountered the...
I had symptoms with my Tungsten E2 where the charging icon would show up when the charger was connected, however, it didn't seem to charge, because when it was removed from the charger hours later, it would still show the same percentage of charge (as read by touching the battery icon while in the favorites screen).
Tried resetting the unit, reconnecting multiple times, different charge cables, and it was always the same.
I thought it might be time for a new battery, so to check it out, I got my T-5 Torx driver, removed the four case screws, and carefully pried open the case from the top (the bottom has hooks that have to be disengaged by sliding the case half downwards after they're separated from the top)
Measured the battery and it seemed to be okay, and after unplugging the battery connector and reconnecting it, it worked normally again. Charged quickly back up to 100%, and the battery is fine.
It looks like something may get out of sync with the battery charge circuit, and by simply unplugging the battery to allow it to reset, it restored operation, no replacement battery needed.
2answers
Cant get the menu display on my pin 570
maybe there is no memory caused by a flat or stuffed lithium battery or battery charging circuit in the pin 570.
fix:
leave unit to charge for 24 h
if the battery still dosnt charge because it is over discharged, then you may be able to push some charge in it after the battery is unplugged, after opening the case, and removing the circuit board.
SPS1 charging system
Borrow a multimeter and check the voltage (and current if you can) going to the battery while the unit is turned off. It should still be charging the battery if it's still plugged into the wall socket. If it is not getting about 13 volts, it's not going to charge the battery. If that's the case, then there's something wrong with the transformer, or another part of the charging circuit. The downside is you can't use the unit without the battery being connected. If the unit still works and sounds good even though it's not charging the battery, then just put the battery on a separate charger every week or so.(I use the SPS1 for my computer and love it!) Good luck with it. H.
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
