Home Logo
patricia condon Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toilet Paper Holder
How does one remove a toilet paper holder without ruining the wall?
Thanks
Albert Getty
Level 3:
  • Master 547 Answers
  • Posted on Mar 27, 2009
Albert Getty
Master
Level 3:
Answers
547
Questions
0
Helped
261013
Points
1266
If it's the kind that is inset you unscrew it if it's the 2 post's attached to the wall look under 2 screw's
Tighten grohe toilet paper holder
Hi!you will remove the flanges in your toilet paper holder there you will see the screw and you will tighten it by screwing it.
Sep 03, 2011 • Home
Moen dn8408ch fell off the wall post. How do I reattach?
There should be a set screw on the bottom. Position the holder on the mounting plate and re tighten screw. It takes a pretty small flat head screwdriver. Here is the pdf format manual for this holder.
http://www.moen.com/shared/pdf/dn8408sp.pdf
How do you get the mounting bracket apart from actual holder piece? My holder pulled out from the wall
The technical specifications and installation instruction for your product are available here.
http://www.moen.ca/shared/pdf/yb2208sp.pdf
At the base of each post; likey facing down to the floor there should be a small square hole. You will need to insert a small flat screwdriver to release the locking tabs to allow the mount to come free from the mounting post.
You will then likely need to remove the mounting posts from the wall; install new wall anchors (suggest you use toggle mounts designed for sheetrock) and then reattach the mounting posts and then the mounts with the paper holder in place.
2answers
PRPH toilet paper holder. the fixture attached to the cabinet and supports the toilet paper holder has a broken post. The post goes into the toilet paper holder and supports it. During remodeling, I...
Without more specific information or a product number difficult to assit; here is the website for the manufacturer where you can search for more information or find a parts supplier near you.
http://www.robern.com/info/documentation.rbn
Trust this is helpful.
I installed a Moen Sage toilet paper holder. The right cover that attaches to the wall hardware via a small screw is loose and no amount of tightening corrects the problem. What am I doing wrong?
It is likely that the the mounting post on the wall has pulled loose.
You will need to remove the paper holder and inspect themounting posts; loosen the set screws in the base of the posts to do this.
Try tightening the screws holding the mounting posts to the wall. If the screws are unable to hold tight you will need to replace the wall anchors if they have been used.
Remove the mounting posts and the wall anchors and replace with new wall anchor, preferably a toggle anchor designed for sheetrock if possible.
With the wall anchors in place attach the mounting posts and install the paper holder; tightening the set screws in at the base of the posts.
Installation instructions for your product can be found here:
Oct 18, 2010 • Moen Home
HOw do I remove the moen toilet paper holder from the wall
Without looking it up, I can figure it has a tiny screw on the flange bottom, and when it is loosened, it will come off, then the holder, keeper, is screwed to the wall. If it is not held on by a little screw, setscrew, then try turning the whole thing off, it might be threaded. Hope this helps.
How to remove the mounting flange from a circular, one-arm toilet paper holder, so it can be re-mounted? there is no set screw to release it-- the flange has two screw holes on either side of a center...
you will need a vary small flat screw drive and at the bottom of the holder the is a small hole insert screw driver and un screw, it has a small screw that holds to the plate on the wall
3helpful
2answers
How to Install Toilet Paper Holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
