I am embarking on a kitchen countertop remodel and I need to know how to uninstall and remove a Jenn-Air jed8430bdb cooktop to facilitate the remodel.
SOURCE: Jenn-Air electric burner goes to full no matter what the setting
This would be a faulty switch. Hope this helps!
SOURCE: I am looking for an owner's manual for a Jenn-Air
I uploaded the owners manual.
Repair information is here
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=653174#d653174
SOURCE: Replacing an old jenn air
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
[email protected]
406.471.0000
