Goldstar DH504EL Dehumidifier Logo
A
Anonymous Posted on Jul 05, 2013
4681a20040j Fan thermal cut off is blown in the fan motor
5helpful
The unit starts but the fan dont run
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
1helpful
AMCOR SD10 Dehumidifier, Need to replace the electric fan motor.
Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
Part cost 98 cents
6helpful
Have power and it runs. fan will not go on.
Part cost 98 cents
Dehumidifier will not extract any moisture & produces no heat
fan not blowing air?
Part cost 98 cents
1helpful
We have a LG LHD65EBL Serial # 603TAAC20984. My Husband said that he thinks the armature in the fan motor is bad. Everything in or basement went moldy over the summer. We heard it running but it was not...
Sure, you can find parts on line, just search "lg parts" then look for you model.
http://www.lge.com/us/support/parts/support-find-parts.jsp
If the fan is not working:Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
Part cost 98 cents
t working the likely problem is:
Someone told me there were lots of fire issues with lg dehumidifiers. Do you know if this is true?
These little units like the one shown are made by the same firm and sold under many brand names.
A common fault for broken dehumidifiers is a blown TCO in the fan motor. A TCO (Thermal Cut-Off) is like a fuse, but opens when it gets too hot. These are non-resettable and are there to prevent burning out the fan motor coil.
I've only come across a couple of slightly charred motors.
1helpful
Bad fan motor on DH504ELY5?
problem fixed with the fan motor not running.
heres how i did it for anyone who experiences the same problem
1.) open back of unit(6 screws and pop tabs)
2.) with back cover open youll have access to compressor and fan-locate the blower assembly and remove the nut on it i used a 3/8 wrench from dollartree and rotated the blower fan while turning-its plastic be careful and remember righty tighty lefty loosey)
3.) with fan assembly off youll see the motor with 2 phillips head screws-taking these screws out with a power screwdriver allows the bearing assembly closest to the fan assembly,shaft,armeture and motor assembly to come out leaving rear bearing assembly attached to chassis
4.) once the motor assembly is completely out gently rest it against the fan hole and cut the silver tape being careful to ONLY cut the silver tape and the first white tape strip.
5.) youll see 3 wires and some insulator sleeves covering them leave everything alone except the ORANGE wire this wire attaches to the thermal fuse than to the windings
CAREFULLY heat up your soldering iron and remove the orange to thermal fuse connection than carefully thermal fuse to windings its a bit of a pain but can be done with patience
6.) remove original thermal fuse noting EXACTLY where original is placed on windings-it will have a small tape strip on it. replace it with one of EXACT OR NEAR THERMAL RATINGS a good choice is radioshack 270-1322. this thermal fuse is ratyed 10 amps max. but remember thermal fuses go by degree of heat and not by amp rating unless the amperage is in excess to melt the thermal material inside-my original fuse was 2 amps and 130 degrees celcius new fuse was 129degrees but plus minus 2 degrees so its a good choice and costs under 2 dollars
7.) place a heatsink clip or needlenose pliers between thermal fuse and solder connections BEFORE YOU SOLDER IT IN PLACE this prevents your 700 degree f iron from melting the fuse(remember its thermal not amperage were talking about here)
solder orange to thermal fuse with plastic extension than flat end to winding wire exactly opposite of how removed
8.) tape fuse in ORIGINAL LOCATION AS OLD FUSE i used scotch tape,place the thermal white protector piece on orange to fuse wire and push everything back down in original places-there should be no contact with any other wires etc. it will cause a fire
9.) once fuse is in place push tape you cut earlier back on and put 2 or 3 small scotch tape pieces of good length to secure the innards, lube the rear bearing of motor using vasoline- a few dollups will do it do the same for front slide motor winding assembly holding it in place than replace armeture with front bearing attaches as they came out secure the 2 screws back in place, put fan blade assembly back on(its keyed) secure nut and reassemble back
if you did everything correctly it will work like new just remember this time CLEAN YOUR FILTER SCREEN REGULARILY lol its critical for proper fan cooling
that should do it:)
Fan motor
I can't imagine why a >thermal< fuse would be insulated as I thought they were designed to melt when the ambient temperature exceeded the stated value
There are some pics of typical thermal fuses here :-
http://shop.ebay.co.uk/?_from=R40&_trksid=m38&_nkw=thermal+fuse
I also have difficulty imagining why they would out such a component in a fan motor assembly - it's not the sort of thing that usually catches fire!
Equally, a non-thermal filament type fuse would normally be placed where it could be seen and replaced. I would expect it to be mounted on a pcb - soldered in, perhaps, but in an obvious place.
We are not allowed to exchange emails via fixya.com, but if you wanted to upload that schematic to senduit.com, and then post the download link here, perhaps I could take a look at the schematic myself.
Sorry this is taking so long to sort out!
Cheers, D.
If the fuse is not
32helpful
7answers
Fan not working
You can purchase a new fan motor. But the same problem will probably happen again. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a yellow thermistor or type of temperature sensor connected between the red wire and a motor winding wire. On my motor this was no longer working (in effect it was an open circuit). Once replaced the motor worked fine. this is the second time in about two years that this problem happened. The first time Sears fixed for about $100 and three weeks. This time I saved the money and did the repair myself. I would guess you could buy a new thermistor for about $5.00 from a parts house like digiKey or National Electronics. You will need to know how to use a soldering iron to repair this.
Top Goldstar Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
