Input wires broken loose, not sure where the go to
All of the wires have been torn loose from the input jack of an ibanez acoustic aef37 and im not sure which wires go to which pins on the xlr input. I have been trying to find a wiring schematic of that particular gutair electronics but i havnt been able to find one.
i believe you need a 1/4" unbalance plug for the amps input. Basically a guitar cord. If I am understanding the question. ? or if you want to know the actual "input jack",Maybe it is lacking or missing? than that would be a "1/4" unbalanced input jack". good luck, I hope this helps.
It calls for a stereo input jack? I'm not sure but I think It is probably calling for a 1/4 unbalanced input jack , keeps your signal mono. so if you are only getting the bridge pickup. You might check your position switch. and or your lead pick up. simply take the designated wire from the lead pick up and hook it up where your bridge position pick up is connected. (disconnect that first) if you get sound, then it just may be your switch. if you get nothing? check to make sure you have your ground correct and he lead wire correct. If these are active pick ups? you''ll need a battery source. if stil get nothing. your pick up may be bad.Thats a reads digest troubleshooting explanation. check your basics first. good luck
I my market, I see used ones in good shape go for $250. Your market may vary. Of course the condition of your particular guitar is a factor, as well as the market you're in. Music Go Round is asking $289 for one, but I expect it will really sell for $250.
I'm unsure what you mean by "bit". Are you perhaps lookng for the retaining nut that screws onto the jack fron the outside to hold it onto the body? If so, they are available in a pack of various sizes from Radio Shack.
It sounds like the guitar pickup may be faulty. It may be a loose connection on the which could be soldered easily or it may be damaged in some other way.
As this is isolated with your G string, I suspect the individual pickup unit is at fault.
If the sound you when plugging in the headphones is coming from the main speaker, it is just the interupt contacts on the headphones are making or breaking contacts. This can be a good sign if there is volume to it.
Make sure the plugs you are using are the right length for jacks in the Ibanez as there are 5 lengths in use.. If this just developed, the length issue is not a concern. If the jacks are loose, snug them down, it may be a faulty ground relying on the chassis contact with the jack.. It may be a broken wire. It can also be a dirty switch contact or dirty level control, especially the standby switch. make sure they are clean with some contact cleaner. Make sure your level is turned up too,
If you have effects, or a preamp on the guitar, make sure they have fresh batteries or good power connections and are not on mute.
The input cable MUST be a TS (unbalanced cable) to turn the unit on. The sleeve of the input cable is what connects the battery. If you use a TRS cable at the input it likely will not turn on. A TRS cable has a tip, ring AND sleeve like many 1/4 inch stereo cables.
The batteries are turned on by the guitar cable being plugged in. If they run down with the cable out, the contact of the "ring" part of the jack is shorting. The "ring" contact is shorted to the sleeve contact to turn on the battery. If you leave your guitar cable in for a day or two, the batteries will run down.
