I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
