If you want to unlock your Sony Ericsson P990i mobile phone from the network lock,you can get network unlock code from Theunlockarena.com at reasonable price.Here they ask you to specify the country name,current network provider and IMEI number of your mobile phone.After specifying these details,they deliver an unlock code through email.Then you can unlock it using code by following the instructions given for your mobile phone from that site itself.
Hello
You can generate the code by using this tiny software.Just follow the procedure.
1.
Downoad [ANT] Simple Ant Simple.zip
2.
If you have Nokia PC Suite running, be sure to close it by exiting from the
taskbar icon.
3.
Extract [ANT] Simple ] and run Simple.exe located in the folder
4.
Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when
prompt a message in your pone.
5.After
you've connected your phone, Click "Read Info"
6.
On the MAIN tab, click on GET. Your phone IMEI number and model should be
displayed on the bottom panel
7.
Now click on the SERVICE tab and click on GET button under USER CODE
8.
Your security code should now be displayed on the right side of the application
window.
If you could not understand follow this How to Generate Your Phone Security code..Only for Nokia bb5 after this format the phone by using the code.Good luck
Thanks For visiting Fixya
You can generate the code by using this small software
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
For details you can from this link How to Generate Your Phone Security code..Only for Nokia bb5
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel as shown below
If you could not understand How to Generate Your Phone Security code..Only for Nokia bb5
