Posted on Mar 27, 2009
Help my A045 Gestetner will not load paper after several short beeps
  • Anonymous Mar 17, 2014
    I need drivers for a Gestetner A045
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 31, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
6221
Points
6
If you are changing a paper roll, make sure you can advance the paper through the "throat" using the green knob and then manually trim it. If you are loading paper in the cassette tray, make sure you adjust the green sizing guides to match the paper dimension (8.5x11", 11x17), etc.
We purchased a Gestetner A045 7 years ago. We are now upgrading to Windows 7 and we have been told that it would be best to get a new plotter because the plotter is not compatible with Windows 7 64 bit
if you search google for the plotter model and it will let you download a windows 7 driver cos i just looked and there is one, try this:
http://www.driverplatform.com/file_a045.html
Looking for some one to work on a gestetner a045 in louisville ky
Your Gestetner A045 is made by Ricoh. I will be a lot easier finding a Ricoh dealer than a Gestetner one. Here are the equivalent models for your machine. That is, any dealer listing that they service Ricoh, Savin, Lanier or Gestetner should be able to service it.
Your machine is the same as:
Ricoh Aficio 240W
Savin 2400WD
Lanier LW310
Good Luck and Thank You for using Fixya.
WheatlandServices
In scanplot base software in A045 machine gives error when you run error is below You donot have memory access. Notice you have the instructions in user manual(RW-240 scanplot setting)? but i have checked...
This requirement and solution are in the Plotbase manual, not the copier manual. See pp. 29-30 Setting for RW-240 ScanTool.
1. Start - Control Panel - Administrative Tools
2. Local Security Policy
3. Local Admin Policies
4. User Right Assignments
5. Lock Pages in Memory - Local Security Setting
4. Add User or Group, then Advanced
5. Add or Find Now - select users (all)
6. OK
7. close Local Security Setting windows
Kyocera mita copier (printhead repearing ((led))
change toner... if that doesn't fix it then change the drum...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2answers
GESTETNER A045 RW-240 PLOT CLIENT/WEB
the pc you have installed the plot server should be login as local admin
Toner code sc300-01
Need aN INSTRUCTION MANUAL FOR gESTETNER COPIER, AS I CAN'T TELL WHAT THE SIGNS AND SIGNALS MEAN WITHOUT THE MANUAL.
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
