whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
It sounds like the drive is ready for replacement. It may be that the laser lens is dirty so the drive never detects a disc, or it's gotten too weak from age and use. Replacement drives are very cheap, so the best thing to do is replace the drive. You can get a DVD burner now at Newegg (www.newegg.com) for $25.99.
If you have a flash drive or even a cd-burner, this problem is rather simple.
On your laptop, go to the C drive, Program Files, and the internet browser file. Delete that file.
Then, on your desktop, go to the C Drive, Program files, and the internet there. Copy all of the files under that browser into your flash drive or onto a blank CD. Then take the flash drive or cd out, and copy all the file you just loaded onto them onto the Program Files on your laptop. Then try and open the web browser.
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Maybe I can help;
When I install a new hard drive I like to re-install the operating system (OS) as well. Unfortunatly this wipes out all your files.
Typically when files do not copy it's either because they're in use or the media (your new hard drive) is not formatted properly.
Note, formatting erases everything on the drive being formatted.
Instruction for this are easy to find online but are all done for you if you use the OS install CD which will walk you through the setup, formatting, and partitioning.
If you have a way to save your files to another drive such as a usb thumb drive, external hard drive, cd or dvd, I would go about it that way. There's usually alot of uneeded files created by the operating system after a period of time and there's no sense in keeping them. They only slow your system down.
One other thing you can consider if you don't have an external hard drive is purchasing a hard drive enclosure for your old hard drive. You can find them at Best Buy. I paid about $30. Its just a case and usb cord you can use as an external hard drive and also copy any files you can still access on this old drive over to your new one.
You may want to double-check the "error" message. Normally, when you insert a blank CD-R or CD-R/W you'll see a pop-up message that says something like, "you've inserted a blank CD. What program do you want to use to put something on it?" And then it will give a list of programs like Windows Media Player, Nero Burning ROM, Roxio, MyDVD, etc. The last two choices are "Open a writeable folder" and "Do nothing." The next to last, the open folder, option is the CD recording option for Windows. Once you've put copies of that data into the new window click on the "burn these files to disc" link on the left side or located under the File menu at the top of the window.
Now, if it truly is telling you that you have to insert a blank CD, then you may have one of two problems. Either the CD you're putting in is NOT actually blank or the drive is having problems recognizing the media. To test the first scenario, try the disc on another computer. If it's truly blank, then try uninstalling the CD burner from your Device Manager located in the Windows control panel. Double-click on the System icon > Hardware tab > Device Manager > click on the (+) symbol next to DVD/CD-ROM drives and then highlight your Sony CD burner > right-click and in the menu choose Uninstall. Reboot your system and let Windows redetect the drive and reinstall the drivers (You may want to have any install discs handy, just in case Windows asks for them, but not likely).
Need some more information:
-What exactly is the error message?
-How long does it take from when you start the copy proces for the error to occur?
-What program/procedure are you using to copy files to the CD-R?
-What operating system are you using?
