I have IES-1000 with 1 AAM1212 ADSL 12 port module.
I have directly connected first port of TELCO cable into a user CPE ADSL router.
Also, I have a cisco 1721 router connected to Ethernet 2 of AAM1212 module and 1 WIC-1ADSL just connected to Internet. On the Cisco Fastethernet I have configured 12 sub interface each one with rispectively VLAN tag (port 1 DSLAM => VLAN 11, ecc,).
Now I would simply a step-by-step guide to configure AAM1212 to permit my every CPE to navigate on ADSL enabled on cisco router.
Going through the GUI would take too long, so use CLI to add the commands below. After that, check the GUI and see how those changes appear.
VLANs:
On all equipment use 802.1q tagging. The example below puts adsl ports 1 to 10 in vlan10 and ports 11-12 in vlan2. These vlans are 802.1q tagged on the ethernet ports.
switch vlan set 1 1~12:X enet1~enet2:FT DEFAULT
switch vlan set 2 1~10:X 11~12:FU enet1~enet2:FT VLAN2
switch vlan set 10 1~10:FU 11~12:X enet1~enet2:FT VLAN10
switch vlan set 17 1~12:X enet1~enet2:FT VLAN17
switch vlan pvid 1~10 10
switch vlan pvid 11~12 2
switch vlan pvid enet1~enet2 1
switch vlan priority * 0
switch vlan gvrp * disable
switch vlan frametype * all
switch vlan cpu set 1
ATM circuit:
Each port requires one or more VPI/VCI circuit. You could map different circuits to corresponding vlans. The config below creates a primary circuit 1/35 on each port. On ports 5 and 9 is another circuit 1/32 mapped to vlan10
adsl pvc set * 1 35 super DEFVAL
adsl pvc set 5,9 1 32 10 0 DEFVAL
Remember a dslam is just a switch, bridging packets from a VC onto a VLAN or straight onto ethernet.
