I had a blackout and as power went out, the tv sounded like a pop and turned off. Now I can plug it in and the power light turns to red, and i can press power and light will turn to green, but i have no image. I cannot change to a different input source, or maybe I am and just cannot see.All four fans in back work when power is on too.
No problem dont be afraid to take the back off the tv check all fuses on all boards especialy the board on right side wich is the video process board controlls all video function if its not fuses check board i had same problem replaced mine so far so good good luck mark shalme
if your still not sure i went to micro center for an esimate to repair my 42 inch luce plasma tv and the tech told me a minimum of 1000 dollars so after the paramedics revived me i new exactly were not to go to for repair and that me being a tech my self the negative feed back i got from micro center encuraged me to fix it my self i had same problem with my tv if your still not sure messenger me back at [email protected]
