SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
