I don't have a remote just a universal remote I use for it. How do I change the clock without having the original remote for it?I don't have a remote just a universal remote I use for it. How do I change the clock without having the original remote for it?
Like I said, I do not have the original remote for it. Is there any way to change the clock without the original remote?Like I said, I do not have the original remote for it. Is there any way to change the clock without the original remote?
You can't post conmments that contain an email address.
Check here for a similiar model: http://download.jazel.net/misc/filecache/3f/3fca776cb32a0a5f4402168c2ef88bbe_1071-ManualHSU448.pdf
You have the remote box? Most functions, clock/date set, channel add/delete and so on are done with the remote, and cannot be so done with the limited buttons on the VCR itself. Early VCRS (pre-90s) were setup with these VCR located buttons.
If you go into the menu you should see clock setting,there will be manual or auto,set to auto and the clock will set its self,even if the vcr is turned off.
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
dvcr-810 series a :steps 1. Press "VCR MENU". The VCR menu screen will appear. 2. Press < or > to select the "SYSTEM SET UP" option, then press ENTER. 3. Press < or > to select the "CLOCK SET" option, then press ENTER. 4. Press < or > to set the month, then press ENTER. note: To make corrections any time during the process Press CANCEL repeatedly until the item you want to change blinks, then press< or >. 5. Set the day, year and time as in step 4. 6. After setting the clock, date and time starts functioning automatically.
you know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Here is a link to your owners manual:
http://www.tacp.toshiba.com/tacpassets-images/models/SD-v393/docs/SD-v393_om_e.pdf
It explains how to set the clock on pages 24-26.
