My monitor wont turn on.....i bought a new ac cable and still doesnt work ....the little light on the power button turns on like for 5 seconds and sometimes it doesnt even turn on....the other cables work its just that wont turn on
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
SOURCE: HP w2007 monitor will not turn on.
The only troubleshooting step I can offer here, is unplug it, and press the power button down for about 15-20 seconds, to flush any trickle power remaining in the unit. Then plug it back in, hook it up and try turning it on again. If this solves it, great! If it doesn't though, then I would check either with HP directly or with your place of purchase to see if your issue can be covered under limited/extended warranty. If you are out of warranty though, LCD repairs tend to jump pretty high, and usually end up being more than what the monitor is worth, so it may be more economical to replace it at that stage.
SOURCE: HP L1906 Flat Screen Monitor Power Light Flashing
http://www.fixya.com/support/t558081-monitor_will_not_power
SOURCE: Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
