Lands Phones Logo
Posted on Mar 27, 2009
Name Display NEC DTerm Series i
How do I change the display name on the NEC DTerm Series i phone?
I have found a document that explains it but it says I need a ''Name Assignment Access Code'', what is this and how do I find out what it is? I tried the extension of the phone but it just gave me a busy signal.
Thanks to any help you can send my way.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4234
Points
It is changed via MAT or MOC programming. See you PABX Technician.
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
How to change name on nec dterm 80
You need to do this from the Admin phones, by default the lowest ext #'s on the system.
This is system programming not the phone itself.
Refer to the Attendant guide for the phone system model your phones run on.
3answers
I am trying to change the name displayed on my nec i-series phone. How do i do this?
Assuming you are not an NEC trained Tech and your system is on a IPKII, You will best served by acquiring the IPKII Instalation manual and the Feature and services Manual.
This is not the kind of simple change that the average end user should attempt although I would agree that it is a feature that should have been made availiable to the average user because of occasional movement in
any office environment.
How do I chance the names on an NEC phone
NAME DISPLAY
NOTE: Display Dterm
A name with up to 16 characters can be entered to display the name on
other Dterm telephones when making a call.
• Press Speaker key, Receive dial tone.
• Dial the Name Assignment access code and receive special dial tone.
• Using the keypad, depress the key with the desired letter to display the
first letter on the key. The
display will indicate the
numerical designation.
Subsequent depressions will
advance through the letters
on that key. The Dial Pad Key
TABLE can be used as a
guide to indicate the key and
the number of depressions required to display numbers, letters, spaces
and periods.
• When the desired letter is displayed, depression of the Transfer key will
change the letter to a lower case letter (default is upper case). Depress
the Hold key to enter that letter and advance to the next entry.
• Repeat the previous two steps until the desired name is displayed and
entered
I need to change my display name for my Dterm 80 phone. I also need to add a name and extension
you need to access program mode on the phones.
mb 4-18 is name assignment
new station is 4-10
ldtsnj.com
12helpful
Trying to change the name on the display on the phone
Dial 700>dial your ext #>enter name>press Hold & press Speaker
Name on display
depends on the phone system, but it is done in program mode. unless its ipk2 tahn speaker 728 allows you to enter a name. ldtsnj.com
Name display
you need to get into program mode to change the display name.
It also depends on the type of system.
ldtsnj.com
NEC Xen IPK
you need to be in program mode to change the names.
check out ldtsnj.com for help
1helpful
NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
