Should be a recovery system partition - hidden on hard drive
https://www.youtube.com/watch?v=NOJd2Hul-6s may be this that I found below to access recovery options -
BE AWARE you may lose any data and installed programs on your computer hard drive when re-imaging hard drive back to factory default
Press F8 during bootup to open Advanced Options.
Select Repair your Computer.
Select keyboard layout.
Select User name and Password. If Administrator account is disabled use another account.
Select in System Recovery Options the Fujitsu Siemens Computers Recovery
Restore Factory Default Settings to restore the system image.
Select the source From hard disk (recommended).
Last confirmation to restore the image.
Most laptops have a switch on the front of the machine. Mine is on the left but some are on the right. There is usually a light that either comes on or changes color. When you turn on the wireless.
Hi, No that not normal. Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off. Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop. If the light comes on then it's charging. If it doesn't then there is a problem with the laptop. I would recommend giving Fujitsu a call as their customer service is excellent.
Go to http://support.fujitsu-siemens.com/com/support/downloads.html under select product choose notebooks then choose esprimo mobiles Then select esprimo mobile V Then select Esprimo movile v5545 expand windows xp Selec t windows xp expand modem click on download download the modem software right click on the zip file click extract all browse to the newley created folder FSC_ConexantCX20548_76200_1017149 browse to winxp run setup.exe
