When I try to plug in my tomtom 130 the chargers are not charging the unit unless I hold the charger a certain way. I think the usb port is the problem but I am not sure at this point. Can you please help me out?
It sounds like your mini usb connector is damaged or one of the components near to it. If you're handy you
can buy a replacement and solder it in. You will need a very fine tip
soldering iron and a magnifying glass. The repair can be quite
challenging as the components are surface mounted. If it's a damaged component near the USB connector that is damaged then this wont solve the problem.
I can fix it for you for a small fee if you dont want to attempt repair.
I've repaired about 20 tomtom units with similar problems. I charge around £35 for this including return postage
Try to buy another cable trust me they are pretty cheap
