Question about Hotpoint Refrigerators
Hotpoint csx25gr, not cooling. Freezer defrosting
I have a hotpoint csx25gr. The hot side is not cooling. The freezer side had some ice to the back but its defrosted everything now. It was keeping a little cool but the freezer side is hot now. It just started to make a whinning noise. Could this be the defrost timer or something simple? Do you know a replacement part #?
  • Hotpoint Master
  • 756 Answers
Your whining noise could be many things...
The LINK on the bottom will help!
DEFROST TIMER
$9.50
Anthony
Hotpoint Refrigerator Defrost Timer Part Wr50x10006
WR9X502 GE Refrigerator Defrost Timer Replacement
How To Fix Refrigerator Making High Pitched Noise
Posted on Dec 03, 2017
SOURCE:
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
mumma_1
  • 903 Answers
SOURCE: Freezer is completely covered with white ice
sometimes a faulty door rubber can make the freezer work overtime. Does the door close firmly?
Posted on Oct 25, 2008
  • 306 Answers
SOURCE: Amana side by side not cooling
The freezer fan has to work in order to move the air inside the cabinet. Now take out the back panel, molding and look at the small fan unplug the frig and remove the fan. Save the fan blades they just press on so will take a little effort to remove the blades. Take the motor to parts house in your area and replace it. Let me know how things turn out. ken
Posted on Dec 03, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Frost is forming in the freezer Hotpoint ctx21ga
I am looking up your model now, it is for sure in the defrost circuit that is causing this. Yes, from what I can find your model has a defrost timer. But have not located where it is, most times 2 places, behind kick plate near floor or inside fresh food cabinet inside the panel where the temperature control is located. When you locate it slowly turn clockwise until refrigerator stops running. At this point it should be in defrost. If timer does not work it will need replaced. I'm still doing some searches on your model so please understand this is not a solid yes, that this is your problem, but we will find it. Let me know what you find, Thanks, Sea Breeze
Posted on Apr 20, 2009
SOURCE: Hotpoint CTX21DA defrost heater not working
Heater coil can be checked with a continuity meter, just be sure to unplug the unit first. Before you do anything, locate the defrost timer which is under the control panel in the fridge at the top in the back. There is a little white plastic plug cover a small hole, remove that and you will see the manual advance device. You can only turn it one way due to its design, so using a flat bladed screwdriver that fits the device turn it slowly until you hear a click. then listen in the freezer for sizzling noises as the heater warms up. If you hear the noise you will need to replace the defrost timer, part is available on line. If it doesn't activate the timer then check the continuity on the heater element and the defrost thermostat. (You will have to cut the wires on the thermostat to accomplish this) and check it for continuity. The thermostat needs to be frozen to read properly otherwise it will appear to be open so leave it in a freezer for a bit then check it out. all the parts are available online, just google for refrigerator parts and look for your model.
Posted on May 20, 2009
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
Freezer stays cold, refrigerator does not. icing under back panel in freezer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 01, 2010 | Hotpoint HSS25GFP Side by Side...
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Sep 21, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
I HAVE A HOTPOINT FZM80 UPRIGHT FREEZER. THE INSIDE BACK OF THE FREEZER IS SWELLING LIKE A BELLY. THIS IS FORCING THE DRAWERS OUT AND THE DOOR WONT SHUT. ANY IDEAS?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Hotpoint Refrigerators
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Apr 24, 2007 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
532 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
