If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV(warranty was expired ofcourse) and found four bulged capacitors. Many electronic companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices.
Here are some options .
1. 1. Have it fixed by a professional
2. 2.. Dig into your TV, find PSB, Check for faultycaps. If you find some(bulged orleaking) bad caps replace the entire board
3. 3. Remove and then replace individual faultycaps. This takes some solderingskill.
Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
Hope this helps
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
When the tv wouldn't turn on, we decided to unplug it. Then when we plugged it back in it made a loud screech. HELP!!
