Replacing distributer suburban 1500 m 1997
HOPE YOU DIDN\'T TAKE OUT THE OLD ONE YET !!!!!!!!!! YOU MIGHT WANT READ UP ON THIS BEFORE YOU DO. BUT THERE ARE PROCEDURES, DISTRIBUTOR MUST BE MARKED, @ BASE/ENGINE BLOCK, USE PAINT, ROTOR MUST BE FACING #1 SPARK PLUG, #1 PISTON NEEDS TO BE SET @ TOP-DEAD-CENTER, ON THE COMPRESSION STROKE, NOT EXHAUST STROKE, IF YOU REMOVE THE VALVE COVER DRIVERSIDE IF V8, YOU CAN SEE #1 ROCKER ARMS. WHEN ROTATING THE ENGINE, MANUALLY W/WRENCH, BFW, BIG-FU-KIN-WRENCH, BOTH ROCKER ARMS WILL BE EVEN & LOOSE, IF YOU REMOVE #1 SPARK PLUG, THE TOP OF THE PISTON WILL BE @ TOP OF ITS STROKE, ALSO, TIMING MARKS WILL BE INLINE @ CRANKSHAFT DAMPER. @ 0, TOP DEAD CENTER. WHEN THIS OCCURS, YOUR @ TOP DEAD CENTER . DO YOU UNDERSTAND ???????? BY REMOVING ALL SPARK PLUGS IT WILL BE EASYIER TO TURN THE CRANK. ONCE YOU ACHIEVE & SATISFY ALL THE ABOVE PROCEDURES YOU CAN SET IN YOUR DISTRIBUTOR, ROTOR FACING #1 SPARK PLUG TERMINAL, THAT YOU ALSO MARKED, INSERT THE NEW DISTRIBUTOR EXACTLY LIKE YOU TOOK IT OUT, REPEAT, EXACTLY..........................GOOD LUCK!!!
