SOURCE: 3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_6b90afb985d8f4bd
SOURCE: setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps
I take the time to answer your question so please rate me
SOURCE: i put new batteries into both units, the indoor
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
SOURCE: Acu-Rite indoor outdoor thermometer (model 00754)
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - Q: My wireless weather station periodically beeps, why?
A: Make sure that any alert and/or alarm features are deactivated first.
Constant, sporadic beeping is generally due to the unit's ability to
detect a foreign radio frequency of another wireless unit when that unit
transmits a signal. Wireless devices that may cause beeping but are not
limited to these devices are; scanners; computers w/wireless
keyboard/mouse; or other wireless weather instruments. Essentially, any
wireless devices transmitting on a radio frequency have the potential to
interfere with each other. Limit the amount of wireless devices to
lesson the chance of interference. When beeping occurs, one device will
need to be deactivated.
Another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. ALL good now.
