Sounds like your pump is clogged. Take off the lower front panel via 3 ws on the bottom. Get a buch of towels, thiers gonna be water. Right in center front thier will be a white twist knob, about 3 inche in diamter. Unscrew it, this is when the water is gonna come out. If there is a secondary wall, pull it straight out with a pair of pliers. Clean out the pump, also check the little hole to the right leading into the impeller, make sure its clean. Finally put it back togther and try it out, thanks Dave
www.washermd.com
