Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It starts how ever after 2 minutes it stops and go back to the main menu
  • Leo Silva
    Leo Silva Jun 30, 2019
    Como resolveu ?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
493
Points
My life fitness will not was on autowax, im running separate wiring to wax on manual
Anonymous
Level 3:
  • Master 463 Answers
  • Posted on Mar 26, 2009
Anonymous
Master
Level 3:
Answers
463
Questions
0
Helped
247135
Points
1336
Check for a little memory backup battery, probably a CR2032 located somewhere under the control panel.
2answers
PACE DVR. Please Help! Anybody
Try to google the message
1helpful
How do I fix the clock
Push the main control knob (right side of the unit) either up or down, until the Kenwood's display screen shows "Clk Adj." Press the center of the control knob for about a second to enter the clock-setting mode.
  • 2 Push the main control knob either up or down to set the Kenwood's hour display. Stop when the correct hour shows on the screen.
  • 3 Push the main control knob to either the right or left to adjust the minute display. Stop when the correct hour shows on the screen.
  • 4 Press the "Menu" button located in the bottom-left corner to save the changes you made to the clock. This returns you to the main menu
  • 0helpful
    How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
    1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    2. Open a terminal-emulation program on your computer.
      Note: These instructions describe HyperTeminal; other programs are similar.
    3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    3helpful
    Using the stop watch feature
    Dennis,
    "Chronograph" is watch terminology for 'stop-watch'.
    There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
    The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
    There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
    To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
    When I turn on the Wii console freezes in the main menu screen.
    Try the Wii "RESET".
    Here's how:
    1. Unplug the Wii for at least 5 minutes.
    2. Plug it back in.
    Sandisk sansa clip mp3 shuts of and wont turn back on...
    You can set the timer under Auto Power Off and Sleep settings to turn off the Sansa
    player automatically when it is playing for a certain time.
    1. Press Menu button to return to the Main Menu.
    2. Move to Power and select it.
    3. Select Auto Power Off or Sleep.
    -Tha Mp3 Doctor
    Main menu
    If you have one of those cartridges with the many games on one then you have to turn it off and start again it is annoying but it stops the game from freezing. I have never heard of the b button going back to the main menu so you'll just have to turn it off every time sorry.
    1helpful
    4answers
    Unlocked european phone MMS
    wrong! ive got an unlocked european phone and i got these settings that cingular WOULD NOT give me off the net
    -= MMS Web Session =-
    Menu -> Web Access -> Web Sessions -> Menu -> New
    Homepage: http://device.home
    Service type 1: WAP
    Gateway IP 1: 066.209.011.061
    Port 1: 9201
    Domain 1: (blank)
    Service Type 2: WAP
    Gateway Type 2: 000.000.000.000
    Port 2: 0
    Domain 2: (blank)
    DNS 1: 000.000.000.000
    DNS 2: 000.000.000.000
    Timeout: 10 minutes
    CSD No. 1: (blank)
    User Name: (blank)
    password 1: (blank)
    Speed (Bps) 1: 9600
    Line Type 1: ISDN
    CSD No. 2: (blank)
    User Name 2: (blank)
    Password 2: (blank)
    Speed (Bps) 2: 9600
    Line Type 2: ISDN
    GPRS APN: wap.cingular
    User Name: [email protected]
    Password: CINGULAR1
    -= Message Setup =-
    Main Menu -> messages -> Menu -> Message Setup
    MMS Message Setup (This is very critical)
    Inbox View: Sender
    Srvce Center No: +13123149810
    Auto Cleanup: 5 days
    Email Gateway: 36245
    SMS Alert: On
    Use GPRS: Yes
    -= MMS Message Setup =-
    Main Menu -> Messages -> Menu -> Message Setup ->
    MMS Message Setup -> Server Info -> Menu -> New ->
    Service Name: CINGULAR MMS
    Server Name: http://mmsc.cingular.com
    Web Session Name: (Choose the Web Session you created for MMS)
    set to default
    Main Menu
    power supply regulator and horizontal output transistor.
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
