no. i just took the plug out and placed in another outlet. all outlets are working so i assumed that the console is not working.no. i just took the plug out and placed in another outlet. all outlets are working so i assumed that the console is not working.
Have you taken a VOM (Volt-Ohm Meter) and physically checked for power at the recepticle AND coming out the other end of the power cord?Have you taken a VOM (Volt-Ohm Meter) and physically checked for power at the recepticle AND coming out the other end of the power cord?
You can't post conmments that contain an email address.
Check the connections: Make sure all the cables are securely connected to the TV and the external devices, such as a cable box or game console. Try unplugging and replugging the cables to ensure a good connection.
Check the power source: Make sure the TV is plugged in and the power outlet is working properly. You can try plugging in another device to the same outlet to check if it's functioning.
Check the input source: Verify that the TV is set to the correct input source for the device you're trying to use. Use the "Input" button on the remote to cycle through the available input sources.
Check the settings: Make sure that the picture settings on the TV are set correctly. Try resetting the picture settings to the default settings and see if that helps.
Perform a power cycle: Turn off the TV and unplug it from the power outlet. Wait for a few minutes and then plug it back in and turn it on again. This can sometimes reset the TV and fix the issue.
Update the software: Check if there are any available software updates for the TV and install them if needed. This can sometimes fix software-related issues that are causing the video output problem.
If these steps do not resolve the issue, you may need to contact Panasonic customer support or a professional technician to further diagnose and fix the problem.
If the error is still shown, turn the treadmill OFF and unplug from the wall outlet. Find the cable that goes between the board under the motor cover and the console. Unplug any connections and replug.
If the error code is still shown please contact customer service.
Try holding down the power button for 10 seconds, then unplug and replug the power cord from the system and the wall outlet. If that doesn't work, try replacing the ac power cable.
Either the power supply unit (PSU) cord has gone bad, or the processing unit used to distribute the power within the system itself has something wrong with it, i.e a bad transmitter or resistor on the circuit board. Unless your handy with soldering and finding the necessary parts I would just send it into nintendo and have them fix it. That is of course if it isn't the cord itself. Make sure you check the outlet too, it could be that maybe that outlet isn't getting any power.
I just had the same problem moments ago, if you unplug the power cord from the wall and the unit and let it sit for a few minutes, then replug it back in, it should come back. Unplugging and plugging back in without waiting won't work, you have to wait 2-5 minutes.
Well, you know what assuming will get you.
