Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
Anonymous Posted on Jul 01, 2013
Lffh21f7hwa Have FRIGIDAIRE upright freezer but no owners manual. I need assistance resetting the digital display one the door. Display reads "0F" but temp continues to go up. Contents are thawing. Please assist.
  • Official Brand Answer 4,342 Answers
  • Posted on Jul 03, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467874
Points
5907
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
  • kandy L kelley
    kandy L kelley Mar 04, 2019
    will that turn the freeze because my not coming on
  • Jennifer J Lacks
    Jennifer J Lacks Sep 11, 2021
    Mine is also like this. I have disconnected from power and reconnected to no avail.
Steve Pack
Level 3:
  • Frigidaire Master 7,128 Answers
  • Posted on Sep 12, 2021
Steve Pack
Frigidaire Master
Level 3:
Answers
7128
Questions
Helped
2276145
Points
27978
Https://www.searspartsdirect.com/manual/36wjinv7xg-001428/frigidaire-lffh21f7hwa-upright-freezer-parts
David Smith
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 07, 2014
David Smith
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5257
Points
I have a Frigidaire upright freezer. model # LFFH21F7HWA. on the door of the freezer display its flashing the temperature and its flashing 1hr duration. whats this mean? please help.
5 Related Answers
Anonymous
  • 121 Answers
  • Posted on Jun 25, 2010
SOURCE: Temperature alarm is on on
i would make sure that the coils are all clean, inside and out. make sure the fan runs on the back, the water pan isn't over flowing.
Anonymous
  • 262 Answers
  • Posted on Jan 11, 2010
SOURCE: Frigidaire upright--
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Anonymous
  • 2006 Answers
  • Posted on Jun 19, 2011
SOURCE: Frigidaire upright freezer-Model # LFFH2067DW. twice
http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Freezer-Parts/297216600/0046/253/Model-LFFH2067DW7/1428/0142000?keySuffixId=NA&productTypeId=0142000&searchModelNumber=LFFH2067DW7&subCompDesc=System&brandDesc=FRIGIDAIRE&modelDesc=FREEZER&blt=11
Thermostat is what I would suspect first.
The defrost timer is the next suspect : http://www.searspartsdirect.com/partsdirect/part-number/Frigidaire-Parts/Freezer-Parts/297216600/0046/253/Model-LFFH2067DW7/1428/0142000?keySuffixId=NA&productTypeId=0142000&searchModelNumber=LFFH2067DW7&subCompDesc=System&brandDesc=FRIGIDAIRE&modelDesc=FREEZER&blt=11
I think the defrost heater is probably okay and it is just getting the wrong signals from the above components. But it is item 14 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Freezer-Parts/Model-LFFH2067DW7/1428/0142000/R0805140/00003
John Lugo Jr.
  • 6 Answers
  • Posted on Aug 29, 2011
SOURCE: We have a frigidaire upright
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Aug 14, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire gallery upright freezer door ajar light staying on and alarm keeps going off....still maintaining 0 degrees temp
    Control board is miscommunicating with the rest of your unit. Contact a professional.
    1helpful
    2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
    The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
    Freezer cools fine but will not shut off till I open door
    Running all the time means you either have to clear/clean your condenser... Check for good tight door seals... and make sure the doors/vents are not blocked by any contents...
    Free flowing cold dry air inside... sealed compartments is ideal.
    Dollar Pull test:
    Use the dollar bill pull test all round your doors...
    (brown paper sack is cleaner & nicer):
    You can take the paper...
    close the door on it..
    Pulling it out you should feel mild but constant pressure around the full perimeter of each door (or drawer).
    If you do NOT feel it the door/drawer needs to be checked for gasket integrity... and the door may need to be adjusted.
    New door gaskets are not terribly expensive
    (but most issues are caused by spilled food, cleaning
    or door adjustments = easy).
    (FULLY covered in every owners manual I've read).
    Consider purchasing 2 TAYLOR BRAND refrigerator
    thermometer & turning the freezer to the ZERO Fahrenheit
    area and the refrigerator to 33 or 34 degrees above zero
    (32 degrees Fahrenheit... being frozen eggs & milk (too cold)).
    Else... comment me back...
    We can take this all the way into refrigerant level check if you find NOTHING ELSE WRONG
    ((HIGHLY IMPROBABLE... but do-able)).
    You gasket is showing as no longer
    available... at appliancepartspros.com...
    So be gentle!!!
    http://www.appliancepartspros.com/frigidaire-gasket-door-white-216522312-ap2113453.html (Frigidaire 216522312)
    2helpful
    Let's try this again. My frigidaire freezer model Lffh21f7hwg, the display board reads "of". How do I reset it. I do not have the owners manual.
    I appreciate your post, Clayton!
    From the information you have provided the display board on your Frigidaire freezer reads "OF". That reading means your freezer is off, you should be able to turn it back on by pressing the up or down arrow five times in a row. If you need any additional assistance please feel free to reconnect. I hope this is helpful to you. -Matt
    Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
    Thank you for your post, Cynthia!
    Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
    1helpful
    Error code 0F
    Good Morning Stephanie Garcia, thank you for your post!
    From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
    Lost manual for my Fridgeidare upright freezer 20.5 with the controls on outside. what does 0F mean. and if I need to set it ,we just moved how do I set it?
    Hey friend, thanks for your post!
    From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
    How do i install a new door gasket/seal on my Frigidaire upright freezer model # LFFH21F7HWA ?
    Good Morning Friend,
    I understand you want to know how to install a new door gasket on your Frigidaire freezer, model# LFFH21F7HWA. Typically this is not a do it yourself repair, as there are no step by step instruction manuals that will tell you how to do this. I suggest either contacting the manufacturer or your local authorized technician for further assistance. The technician has been trained on your specific appliance, and should be able to replace the new gasket with ease. Hope this is helpful.
    -Best Regards-
    WP
    4helpful
    My new frigidaire freezer the digital display on outside of door flashes off what to do?
    Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
    The temperature display is reading 0 degrees
    Zero degrees F is the normal operating temperature for a freezer. The compressor should not come on until the time is above that.
    Top Frigidaire Freezers Experts
    ZJ Limited
    ZJ Limited
    Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
