How to change temperature from Celsius to Farenheit?
Https://skyscanatomicclocks.com/site/owners-manuals/model-86709/
Manual explains how to change by pressing the C/F button.
What product and model are you referring to please.
What make and model device?
Or are you asking in general? To convert from C to F, multiply by 1.8 and add 32.
Testimonial: "plesae not this item is not a clock radioITEM DESCRIPTION: wall / desk CLOCK (plesae note this item is not a clock radio.) MAKE: SIOSCAN ATOMIC CLOCK MODEL: 86709R PROBLEMUNKNOWN EVENTHAS CHANGED tEMPATURE DISPLAY CO CELCEUS NEEDED INSTRUSTIONS: TO CHANGE TEMPATURE DISPLAY BACK TO FERINHITE "
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
