I ADDED SOME PICTURES TO MY EXTERNAL SD CARD AND WHEN I MOVED ONE OF THE PICTURES TO INTERNAL MEMORY....WHEN I WENT BACK TO VIEW EXTERNAL SD CARD, IT WAS GONE. THE CARD IS INSERTED BUT NOT SHOWING ON MY PHONE AS IT BEING THERE
You can download a file recovery software to retrieve the lost sd card photos.
SOURCE: Micro SD card is not recognizing photos and won't transfer info
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
SOURCE: Micro SD NOT WORKING (SONY ERICSSON W580i)
turn phone off, insert micro sd card in - logo side up and reboot. worked for me. i experienced the same problem.
SOURCE: LG banter won't recognize data on SD mirco card
Please try to back up the music and picture that you have on the memory card, try to format the card using the phone before transferring the music and pictures again. Try to consider the memory capacity of the card, make sure that it is compatible with the phone.
SOURCE: MY phone doesn't recognize my sd card...
Format your card in pc. Use FAT format.(No FAT32 or NTFS). Then insert it to your phone and do format again. Then restart.
SOURCE: I cannot play music off my sd card on my lg banter phone
i think you need to re-program your phone
i hope in can help you
