There is frost in the freezer. I thought it was frostless.
If you live in a humid environment its the water vapor in the air that is turning to frost in your freezer. Every time you open the door you are exchanging the cold dry air in your freezer for the humid air on the outside, and when you shut the door closed its this humid air that turns to frost inside the freezer. If its building up frost faster than normal you might have a door gasket that is leaking the cold air outside thus letting the humid air in, which is turning to frost. Check that your door is aligned properly and that the gasket is secure on the freezer door.
Hope this helps explain it.
