Samsung Prostar DCS-24B-LCD Corded Phone Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RING TONE VOLUME TO LOW
HOW DO YOU INCREASE THE VOLUME OF THE RINGTONE FOR IN COMING CALLS.
george peters
Level 3:
President:
  • Master 860 Answers
  • Posted on Mar 26, 2009
george  peters
Master
Level 3:
President:
Answers
860
Questions
0
Helped
609269
Points
3471
While the set is ringing use the volume arrows next to the handset to adjust the volume.
Anonymous
Level 2:
Director Badge:
Uploaded 100 video answers.
  • Expert 213 Answers
  • Posted on Nov 02, 2010
Anonymous
Expert
Level 2:
Director Badge:
Answers
213
Questions
0
Helped
100007
Points
265
You can permanently adjust the ring volume on Samsung telephone systems by watching this video;
  • Anonymous Nov 07, 2010
    Try bookmarkinghttp://www.AbbeyTelecom.com as there are 60 Samsung how-to clips there.
How do I increase the volume on ringtone?
made call from other device and without receive call just press Vol+ OR Center key UP
Apr 17, 2016 • Cell Phones
Need loudest ringtone possible
To increase the ring volume, press the up-arrow button.
You can also change the ring tone using the Ringer Tones option in the setup menu.
If you need a manual, you may download a copy here.
2answers
I have problem with my Nokia 2310 mobile phone.. it has very low sound of ring tone.. how can i increase the ringing sound
Dear Sir . Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step : Select Menu > Settings > Tone settings and from the available options: Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls. I hope this will works for you. Regards. Rizwan.
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Incomig calls are exremely low volume outgoing calls have normal volume. Is there an adjustment for this
hi
you can increase your sound by increasing the sound in profile settings.there you can find increasing sound for your ring tone.moreover you can set the ring tone that should have increased quality of your sound.then check the sound in call option.mostly samsung phones speakers have low sound quality
thank you
1helpful
Hi how can i increase volume on my blackberry 9000. Even on high volume setting there is no ringtone sometimes
Hi there
On your Blackberry menu, there's an icon that resembles a person's head that represents profiles. In the profiles menu, you can select the volume for the notifications you receive when messages or calls come in. Choose "Loud" to hear all notifications at an equal volume, equivalent to the maximum output possible.
Some ring tones just remain less audible than others even when they're set to maximum volume. If you've tried increasing the volume of your notifications but still can't hear the ringer sometimes, try downloading a custom ringtone from the Blackberry App Store.
When selecting a custom ringtone, choose something distinctive and hard to ignore. When previewing the tone, determine whether it seems louder or easier to hear than your existing tone. Download more than one tone and experiment throughout the day.
After you've downloaded custom ringtones, set your phone to use these ringers by going into the applicable notification profile. Select "Show Tunes" and open the media folder where you've chosen to save your downloaded tones. Select the ringer you want and click "Set as Phone Tune."
The problems is rintone is very low how increase ring tone
you will need to frist add the contacts to your phone memory then edit the contacts and assign a ringtone to each contact you wish.
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
1helpful
Ring tone
go to setting its in the menu then choose profils the then highlight general and press option to personlize then then chang the ringtone and the increase volume
123helpful
8answers
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
