Dishwashers Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FOOD PARTICLES ON DISHES
MY DISHWASHER ALWAYS LEAVES FINELY GROUND FOOD PARTICLES ON MY DISHES AND I DO USE JETDRY.
  • Denise Gorman
    Denise Gorman Apr 29, 2009
    food left on plates ,dishes, ect there is no way to to clean the little things that catch the food ive tryed ,it seems that everything has food and gritty kind of stuff on them ive used powders and gels please help its a G E ihave had it about 12 years ,but maybe only used it 8 or 9 times ???
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Mar 26, 2009
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2150261
Points
26471
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607721
Points
3590
Check the PUMP AND MOTOR make sure is not clogged Make sure that filter is clean. using a dishwasher cleaner run your dishwasher through the entire cycle on empty. This should help,
Dishwasher cleaners:
1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle.
2. CLR - I've been told it works, but never tried myself
3. Dishwasher Magic - This stuff works pretty good. One bottle per use.
  • Starnley Johnwells
    Starnley Johnwells Mar 26, 2009
    Dishwashers get a build up inside the wash arms and internally in the pump. This build up affects the washability. Run two packages of cleaner thru and then let things go for at least 3 loads.It is possible that the pump is gunked up. Run the cleaner thru.hope this helps
Brada dishwasher leaves film and small sand like food particles on dishes
Always use a separate rinse aid instead of tablets claiming they have rinse aid in them.
Ian
Aug 16, 2015 • Dishwashers
There is food and grit stuck to my glasses. Where is this coming from? I am rinsing all the dishes before I put them in , so it must be in the dishwasher somewhere,
We used to have this problem with a Kenmore that had a built-in "garbage disposal"--it was a little blade that ground up larger food particles. Occasionally a cherry or olive pit would get inside and dull, chip or break the blade, and the symptom was food particles on the dishes. The solution was to replace the grinder.
3answers
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
Dishwasher is throwing food bits back on dishes during wash. How do I clean out dishwasher?
While loading into the machine always remove the food particles from the dishes. The wash machine will clean the sticky oil grease only.
Check the drain filter in the machine and clean. Refer user manual.
2answers
I have maytag dishwasher leaves food residue
there is a filter on the inside bottom of the dishwasher check and clean it
Dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
2helpful
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
2answers
Disdwaser leaves spots on dishes
You simply need to use a product called Jetdry for a couple of weeks until all the traces of factory solvents etc. work out of the machine. Sometimes if you have a really high concentration of particulates in your water the problem will continue and that is what the Jetdry is for. It isn't the new dishwashers problem it is the local water. One permanent solution is to hook up a water purifier/softner in order to clean the water up. Jetdry is used in many areas and is perfectly safe. Good Luck this will help.
Nov 26, 2008 • Dishwashers
Dishwasher is leaving food particles everywhere
Clean the filter screen at the bottom of the washer basin.
Apr 14, 2017 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
