The caller hears a high pitched buzzing when on hold
also the 2nd button lower light button remains on all the time on all phones in our office. Phoen system is a Comdial Executech 6614
Restart your phone system. Let it stay off for a minute.
If problem continues look what is connected to your music on hold port. Look into that media device and conection methods. If nothing connected you will need to contact your local Comdial Vendor.
Cheers
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
DSLReports
Oct 3, 2009 - 30 posts - 7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Nov 8, 2015 - 25 posts - 12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Sounds like trouble in the standby/power up circuit. have you tried unplugging the TV for a half hour and seeing what happens? It might start up but I think this problem won't go away. If you heard a high pitched buzzing it sounds like a problem in the high voltage not letting the start up circuit work. threy are related. The start up circuit waits for the high voltage to stablize and then switches it on.
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
