Can this Soyo TV model#MTPRTPT3208NB be mounted to the wall? If so what wall mount fits it? Tv is 32 inch
SOURCE: Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
SOURCE: cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
SOURCE: TV wall mount screws for Dynex 32" TV, which size?
Orchard supply.....Metric Cap Screw size:
M6-1.0 x 12MM
They come 2 to a package for about $1.39
