Question about Casio Exilim EX-Z77 Digital Camera
Battery won't charge on casio ex-z77 exilim
When the battery is loaded in the battery charger the red light flashes and never stops. The battery will not charge.
  • 4 more comments
  • Anonymous Apr 08, 2009
    Same problem but I dont really have the money to buy  new battery, is'nt there anything else you can do?
  • michelleaa Apr 23, 2009
    same as you guys. oy, this makes me so frustrated....
  • Anonymous Apr 24, 2009
    baterry charger flashes red
  • Anonymous Apr 28, 2009
    Red light keeps flashing even after having checked all connections.
  • Anonymous May 17, 2009
    same thing!!! -.-
  • Anonymous May 20, 2009
    yes this is my problem as well...i thought it's the charger that was causing the porblem..but apparently it's the battry =S
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Posted on Apr 20, 2009
    New Friend:
After having the same red light flashing problem with my battery charger, I found this sight and thought ringing casio would be the best option; unfortunatley we needed the camera on the weekend and customer service was not available, so after thinking about the battery & charger not recognising each other i thought that maybe wiggling the battery whilst in the charging position might get enough charge to make them compatable again. Hey presto it worked, heres what to do, place battery in charging position red light flashing then keeping contacts end in lift battery to 45 degrees, this should give you a continuous red light charge, I held it for about 45 seconds, then put back into normal charging position and red light should stay on!! I wont let battery run down again but saves the hassle of casio on hold music!!
Posted on Dec 24, 2009
  • alisdair_c May 12, 2011
    hartwe1l's solution works, if you have this problem try this before buying a battery or contacting Casio. It took a few attempts to get the right angle, but it worked after a min or so.
    New Friend:
I did the same thing as Hartwe1l, although I didn't tilt it up so high. I just held the battery tight against the contacts and lifted it a little bit, got a steady red light, held it there for a minute, and presto...continuous red light. I'm assuming it's charging...so far, so good! Thanks hartwe1l.
Posted on Dec 25, 2009
You need a new battery.
I ordered a new charger thinking THAT was the problem. When I put the battery in...the charger still had the blinking light. Imagine my frustration - I'd wasted $55 on a new charger, only to find that it was really the battery that needed to be replaced.
If you go to the Casio site, you'll be able to order a new one for $29.99, I believe. The shipping and handling comes out to $8-ish, and the taxes will be $4-ish. I hope that helps!
-sarahPUFFY
Posted on Mar 27, 2009
3 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Posted on Sep 27, 2008
  • 85 Answers
SOURCE: I have a casio exilim ex z77. My battery to my
hi, once you charge your battery and the red light blink it means your NP-20 battery is damage and you need to buy new one.TIP- charge 1.5 hours only and if youre not using you camera for a long time its better to remove the battery.
good luck and thank you my friend
Posted on Jul 20, 2010
Where i can buy a battery of a casio exilim ex-z77 digital camera
You can buy from the following web sites:
http://www.bestbatt.com/Casio_NP_20_Battery_p/bbcasnp20-01.htm
http://www.calcellular.com/casio-np-20.html?gclid=CNTYvOLdo6YCFRZ-5Qod1Us3pQ
http://www.overstock.com/Electronics/NP-20-Camera-Battery-and-Charger-for-Casio-Exilim-EX-Z75-Z77-S770/4384370/product.html
http://www.shopxtreme.com/pages.php?cID=4&pID=11&gclid=CMu9ypbeo6YCFYHc4AodGifKnw
Jan 05, 2011 | Casio Exilim EX-Z77 Digital Camera
Charger light flashing on and off and not charging battery
Hi, once you put your battery to the charger and the red light is blinking its means yor battery is damage you need to buy new. if the red light is steady only it means your battery is OK.
Jul 18, 2010 | Casio Exilim EX-Z77 Digital Camera
I have a casio exilim ex z77. My battery to my camera wont charge when I put it on the charger. The red light just blinks.
Jul 08, 2010 | Casio EXILIM Card EX-S770 Digital Camera
The battery charger is flashing red but doesn't seem to charge. What could be wrong?
This is usually a sign that that the battery is beyond charging. Test the charger and battery voltages with a meter if possible, but chances are that you need a new battery.
Dec 07, 2009 | Casio Exilim EX-Z77 Digital Camera
CASIO EX-Z77 BATTERY CHARGER
Battery is faulty, it has been left to long discharged & has anodised up on the inside. Buy a new battery
Sep 05, 2009 | Casio Exilim EX-Z77 Digital Camera
Problem charging battery
it your batter light is blinking a red light then you should call up casio's technical service and they'll send you a new one:)
call 1-800-435-7732 for technical support! :)
Dec 07, 2008 | Casio Exilim EX-Z77 Digital Camera
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
Bingo, no problem!
Jul 10, 2008 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-Z77 Digital Camera Logo
1,498 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
