It has a german keyboard but instead of the qwertz layout it has a qwerty layout. I tried all keyboard and language input combinations but did not find a correct combination in Win 7. The best one is german with german. Now how can I swap/map the z and y?
The uses for mapping your keyboard are numerous, but
remapping your keyboard's keys is not for the squeamish.
There are numerous software applications to map and remap a
keyboard's keys.
The best part is that the software is free and easily
downloadable via the Internet.
So, go ahead and swap those unused keys on your keyboard to
suit your computing experience, and make your keyboard more effective without
fear of damaging your computer
Place your mouse pointer over a key on the visual keyboard. Notice that the key
is numbered.
To see what function the key is currently assigned to, allow
your mouse pointer to hover over the key.
A pop-up displays what the key is attributed to.
Left-click the mouse pointer on a key you wish to change.
Click on Choose New Remapping from the drop-down menu.
Select Remap Key from the Control area on the interface.
You may also opt to disable or enable the key, and reset the
default for this key.
Left-click Apply. Look at the list box at the top-left of
the interface, labeled "Remapped keys currently in effect."
Ensure that the keyor keys you selected are listed in this
list box.
Fix a mistake by resetting the defaults.
Click on the top button adjacent to the list box you just
visited.
Pressing this button will remove all the changes to your
keyboard mapping.
SharpKeys is a Registry hack that is used to
make certain keys on a keyboard act like other keys.
http://www.randyrants.com/2008/12/sharpkeys_30.html
SOURCE: Keyboard and mouse not working
try reinstall the chipset driver your laptop/pc this might problem with driver, if still not working maybe cause by hardware failure or os damage files.
*resintall the driver.
*clean install xp
SOURCE: i was given an acer
Follow this instruction:
In German: Systemsteuerung-Regions-und Spracheinstellungen-Tastatur und Sprache-Wählen Sie eine Anzeigesprache
In Engliish: Control Panel-Region and Language-Keyboard and Language-Choose a display language
In Dutch: Configuratiescherm-regio en taal-toetsenbord en de taal-Kies een display-taal
SOURCE: I want to change my window vista from German language to English language can you please help me?
You can download the english language pack from windows update, that you can find from your start menu, it will be in optional updates.
after you have installed english or if it is already installed, then open control panel, under clock language and region click on change display language, under display language you can change the language to another.
Free Keystroke Converter can customize your keyboard layout, change any key on the keyboard to other keys, replace keyboard shortcuts, execute micro or windows action.http://www.softwaredownloads.org/windows...
