I would check all your setting options. Check for applications that are running in the background, check WiFi On/Off, check GPS On/Off, check 4G (LTE) On/Off, and check for Auto-Updates On/Off. I would also removed Live Wallpapers and unnecessary Widgets that are roaming around the Home Screen. Try to terminate background apps and apps that you aren't using. If you have an app that you launch and ads pop up, sometimes that app will give your phone data roaming if it is not terminated.
If these options do not solve your problem, I would take it to your nearest cell phone provider and check the issue. Some instances they will replace your battery for free.
SOURCE: Hi. My battery life time won't last for an hour
Some files might be corrupted. Try reinstall firmware using SEUS from your PC.
SOURCE: Why does my xperia 10 lose battery life when plugged in?
Looks like your USB connection from your phone to your charger is faulty.
Hope this helps :).
