SOURCE: I have a TCL LCD TV and when I switch it on it gives this sound and a TCL logo.
You can't do it. It is a permanent preset by software.
SOURCE: TCL LCD TV. No sound on one channel only.
I had the same problem... try toggling through the "SAP" (multilingual audio feeds) for the channel. Mine was somehow set on "audio 3 of 3" for that channel, but there were only 2 audio feeds.
SOURCE: TCL LCD TV L42M61AZ
i have the same problem found you can try turning it off and on for ages to get it to work or place a heat source at the rear of the tv for a while and it seems to work. I have also used a hair dryer with success
SOURCE: We have a TCL LCD
Hi.
The problem used to happen with certain receivers that are confused by digital broadcasted signal.
Try the following:
1) Reset the receiver box to factory settings and do a rescan. If receiver is built in with TV, simply do a rescan.
2) Call the provider and ask if they are aware of the problem. They usually are, since the problem depends on TV provider signal not working with certain receivers.
3) Check if a firmware update for the receiver box (or TV if directly connected) is available.
4) If there is no better solution, see if there are duplicate of the same 9 channels in different positions.
In this example with Go Australia the "9" channels where duplicated in positions 350-352.
Alternatively delete manually the nr.9, set the channels as skip, and re-program manually the channels in different positions. Procedure depends on the receiver used.
Regards.
Ginko.
SOURCE: TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
