Vtech DECT 6.0 Digital Cordless Phone Logo
Anonymous Posted on Jun 29, 2013
Voicemail setup What do I press when I want to hear my voicemail.Is990,991 is intro to voicemail setup,if so I have press both of them with know resolve.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Jun 29, 2013
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10440517
Points
622693
What model VTech DECT 6.0 phone? Are you referring to the messages on the answering machine or on the voicemail system provided by your telephone company?
tip
Apple iPhone Voicemail Button Setup/Configuration
Apple iPhone Voicemail Setup/Configuration
Apple iPhone Voicemail occaionally doesn't set itself up properly and has to be configured manually.
  1. Press the phone button on your iPhone. (Green one, bottom left)
  2. Press the keypad tab.
  3. Type the following: *5005*86*yourvoicemailnumber#
  4. Press the call button and wait a few seconds.
  5. Press the voicemail button, and it will now call your voicemail.
UK Voicemail Numbers
O2 - +447802090100
Vodafone - +447785016005
Orange - +447973100973
Three - +447782333123
T-Mobile -+4406477897123456 (77897123456 - being your mobile number without the first 0)
on Dec 23, 2009 • Cell Phones
1helpful
WHEN I GO INTO VOICE MAIL IT TELLS ME IT IS NOT SETUP WHAT CAN I DO?
Tom, set it up again. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to use Message Centre voicemail
http://www.rogers.com/web/support/wireless/voicemail/903?setLanguage=en
Set up Voicemail or MiniMail Service from Your Cell Phone MTS
How do setup or check my Voicemail Koodo Mobile
Mar 12, 2016 • Cell Phones
How do I transfer a voicemail on my phone to someone else's voicemail?
Listen to the complete voice mail, then when it finishes (or you fast forward) choose COPY
You can then record your own voice message intro to the message explaining why you have transferred it.
Once you choose yes or no to recording your own Intro you will get to choose the mailbox you would like to forward the voice mail to.
Enjoy!
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Lost security code toshiba dkt3010sd phone. Need to check messages
I can help you solve this dilemma, but I will need to know what type of Stratagy Voicemail you have to be 100% sure.
Here's a procedure that may work for ya, if it doesn't just let me know which VM you have and we'll get you setup.
Dial Voicemail (usually 100), when you hear the greeting press the * key. When it asks for your User ID, dial 999. When it asks for the security code, try 999 or 999997. Once logged in press 8 for system functions. After that, listen to the prompts and it should walk you the rest of the way through it.
Toshiba dkt3210s reset security code
Knowing what type of System and Voicemail you have would be beneficial to know. This may work for you, if it doesn't just let me know which VM you have and we'll get you setup.
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
2helpful
2answers
How to set up voicemail on i phone
<<This is straight from TracFone support for setting up voicemail on the Motorola C139....enjoy>>
Thank you for your interest in TracFone Wireless. We are responding to
your recent inquiry.
TracFone Wireless would like to take this opportunity to apologize for
any inconvenience this issue may have caused you.
Your voicemail box has been reset. To set up and retrieve voicemail from
your TracFone:
Press the MENU key,
Scroll to MESSAGE and press SELECT,
Then scroll to VOICEMAIL and press the MENU key,
Next scroll to VOICEMAIL SETUP and press SELECT,
The VOICEMAIL Access Number should be: +17044089979 and press the OK
key (if there is no + sign, please press and hold the 0 key until it
comes up).
If the numbers there are different, press and hold the key below the
word CLEAR or DELETE until all the numbers disappear from the screen.
Then enter the number 17044089979 and press OK.
After programming the Voicemail Access Number on handset, please turn
the phone off and back on.
Then, press and hold the 1 key to auto-dial the VOICEMAIL box to record
greeting and complete setup.
Your temporary password can be 0000, 1111, 9999, the last 4 digits of
your wireless number, or another 4-digit number easy to remember.
All calls made to your voicemail from your TracFone will deduct airtime
units. To avoid being deducted airtime, it is recommended that you
contact your voicemail from a land line phone, by dialing your ten-digit
mobile number. To retrieve voicemail messages from a landline phone,
please follow the instructions below:
1. From your landline phone, dial your TracFone Number.
2. When you hear the greeting, press the star (*) key. If the star key
does not interrupt the greeting, press the (#) key.
3. Enter your password and follow the retrieval instructions.
Please note, if this procedure does not resolve this issue, we would
need to talk with you directly for further assistance.
Should you have any further questions or concerns, please contact one of
our customer care representatives at 1-800-867-7183. For your
convenience, our representatives are available Monday-Saturday from 8:00
AM to 9:45 PM EST, and on Sunday from 8:00 AM to 6:45 PM EST.
Thank you for being a TracFone Wireless customer. We appreciate your
business.
Sincerely,
TracFone Wireless
Sep 16, 2008 • Cell Phones
1helpful
3answers
Razor v3 voicemail
Changing the voicemail message would entirely depend on your provider - how they set it up for you and how you can setup your own message. They must have a specific number you can dial to set your voicemail message. This setting is not available on your phone; rather voicemail messages on the voicemail server of your provider. So, the best way out would be contact the provider. Cheers
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
