Video Game Consoles & Games Logo
A
Anonymous Posted on Jun 29, 2013
Nintendo wii error code 262102 when trying to get on nintendo channel
stephan angelo eugenio
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 06, 2016
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2507
Points
Why my nintendo wii updates is so slow
4 Related Answers
Anonymous
  • 47 Answers
  • Posted on Jan 27, 2010
SOURCE: error code 32032 (wii)
you need to set up connection for wireless if its a wireless router then set it as connection 2 then search for your router then input the wep-psk or wpa psk code thats on the back of the router
Anonymous
  • 78 Answers
  • Posted on Apr 08, 2010
SOURCE: wii connectivity errors
this means that the router is not compatible with wii there is no magical fi for this pandemical problem unfortuantly
Anonymous
  • 1234 Answers
  • Posted on Aug 26, 2010
SOURCE: how do i get connection 24 on my wii?
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
_____________________________
Error Code: 51421 The Wii console is not able to connect to your wired router or modem.
Anonymous
  • 10 Answers
  • Posted on Mar 05, 2011
SOURCE: trying to update my wii and it says unable to
Enter the code on nintendo's site. If it is not helpful you can get a disk from netflix.
The error code 51330 keeps coming up when I try to connect to the Internet on my wii
    The following Wii error codes all have the same possible solutions, which you can read below this list of codes...
  • All Wii Error Codes between 51000 and 51099
  • All Wii Error Codes Between 54000 and 54099
  • All Wii Error Codes Between 51300 and 51399
  • All Wii Error Codes Between 52100 and 52199
  • All Wii Error Codes Between 52200 and 52299
  • All Wii Error Codes Between 52400 and 52499
  • All Wii Error Codes Between 52500 and 52599
  • 51130This is a General Troubleshooting error code and does not have any one specific cause. You'll need to try the following steps to try to solve the problem.
    1. Your wireless router sends out an internet signal using a specific "channel" (much like a radio broadcasts over the airwaves). You can change the "channel" that your wireless router uses to broadcast the internet signal manually. Nintendo suggests setting your wireless router to either channel 1 or 11, as these are supposed to be the fastest channels for download speed.
    The Nintendo website has a guide that shows you how to change the channel on your wireless router. https://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
  • 2. In addition to the broadcasting channel, there is also a broadcast setting. This can be set to either "G", "B", or "Mixed." Nintendo suggests that the "Mixed" setting gives the best network connection, but you might need to try all three settings to get the best network connection.
    3. Home appliances and other devices that are near to your console, like microwaves and cordless phones, might cause interference with your wireless network connection, so try turning these off. Other wireless devices like keyboards and computer mice can also interfere with your network connection.
Just moved and trying to set up my nintendo wii. im haveing a hard time to get it my internet on there i keep putting my SSID BUT IT KEEPS GIVING ME ERROR CODE LIKE 51031?
  • https://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
Error code 204038
Error Code: 204038
The Wii console was unable to connect to the Wii Shop Channel.
  • Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
    • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.)
    • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • There could be a temporary network issue with Nintendo's servers. Please wait a few hours and try to access the Internet Channel again.
  • If the above steps did not resolve your issue, please call 1-800-255-3700 for assistance.
Error code 206602
Error Code: 206602 Wii Shop - Nintendo Points Card, or Wii Download Ticket Error There appears to be a problem using the Nintendo Points Card, or a Wii Shop Download Ticket.
  • Make sure you are entering the number in the correct field in the Wii Shop Channel.
    • For Wii Points Card and Nintendo Points Card redemption, select "Add Wii Points" from the main page of the Wii Shop Channel, and then "Redeem Nintendo Points Card." The following screen will have a section for entering the points card number.
    • To redeem a Wii Download Ticket number, such as for the Wii Speak Channel, select "Settings and Features" from the main page of the Wii Shop Channel, and then, "Wii Download Ticket." The following screen will have a section for entering the download ticket number.
  • After verifying you are entering the number in the correct location, retry the number again and make sure it is being entered correctly.
  • There may be a temporary issue with the Wii Shop Channel. Please wait awhile and try your connection again.
If the above steps did not resolve the issue, and you continue to experience problems, please call 1-800-255-3700 so that we can assist you further.
Hi, um.... well my wii isn't doing the internet wifi thing there is a error code: 32002
Hi there.
This error is caused by the Wii being unable to receive an update from Nintendo's servers due to a technical issue.
To solve this error :
Try changing the channel on your wireless router to channel 1 or channel 11 which can increase download speeds.
Thank you!
2helpful
Error code: 051032 when i try to get on wii shop channel to download netflix
This error code means that the only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
Please follow the Nintendo Troubleshooting page for some steps that may resolve this for you: http://www.nintendo.com/consumer/systems/wii/en_na/errors/results.jsp?error_code=051032&system=Wii&locale=en_US&action2.x=33&action2.y=19
Error code 32002 when trying to update
Try changing the channel on your wireless router to channel 1 or channel 11 which can increase download speeds. The error means your wii encountered a connection error whilst downloading the update from nintendo, this could be your internet connection, or too many people on nintendo servers
2answers
Wii system update displays an error code 32007
From WiiErrorCodes.com
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds. Be sure to test both channels to see which works better or faster.
Set broadcast settings on your router to "Mixed." This usually produces the best results. If not, trying setting your router to "G" or "B" to test which works best.
The Wii could be unable to connect to Nintendo's servers.
Please wait and try again.
I hope this helps
1helpful
Why do I get an error code when trying to download a game to my Wii Memory?
Any time I have tried to download from Nintendo Shopping channel, I have gotten an error for one of a few reasons. 1. No Internet Connection. 2. Slow Connection, 3. Connection Drop. or 4. operating system error.
If you provide the error code or look it up on Nintendos website, it usually gives your some hints to fix your issue.
However, here are the most common:
1. This is usually because the WII console is not connecting to the router or getting an IP address. If could also mean your router has lost its connection to the internet (easily checked with any other computer).
2. This is usually due to congestion (per Nintendo) in your area. They say to try changing your channel for the router. I think Nintendo recommends 6 or 11 but it depends on how many people in near you use wireless.
3. This can be a number of things. This time of year, you typically have problems accessing/downloading things from Nintendo just because a lot of people are trying. However, I have wireless N and the WII is wireless G; I have found that sometimes causes drops. Wireless N is constantly trying to get the best signal and sometimes changes channels (at least mine does), this can cause G to drop sometimes. I went to a wired solution, it helps in online play.
4. I have not seen this one of late. But when WII first came out, an update disabled WII connect and Nintendo had to replace the unit.
2answers
Error code 204704
First google result by searching your title:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
