It has a black screen and a green loading circle. i cant see the home screen but i can get wifi updates. says "the application Messaging (processcom.android.mms) has stopped unexpectedly. Please try agian. PLEASE HELP ME
SOURCE: I keep getting an error
Try this.
settings>applications>Manage applications>(select the "ALL" tab)>select "Market"
then "Clear data"
Download the latest market .apk file from
thegadgets.net, make sure you keep it in the root directory of SD card.
Once downloaded, install the market app with the help of apkinstaller
If still the problem persist hard reset your phone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: how do i get rid of error message "the application
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
SOURCE: My LG Optimus Cell
Hi there.
Reboot phone and as soon as it opens up get into settings. If the fault
pops up as long as you are in settings you are ok. Hit force close and
navigate into your app manager and uninstall the last thing(s) that you
got from the market. Basically, if you
downloaded more than one app and soon after you are having the problem
dunk all of them.
Hope this helps. Let me know if you need further assistance.
Thank you for using Fixya!
SOURCE: hello, my lg optimus swift is
my lg optimus swift is not working correctly. when i turn on the phone, sometimes it displays this sorry! the application Android Phone (process com.android.phone) has stopped unexpectedly. And it not receiving or sending any calls with the signal only dropping.
Had same issue. Done reset and it stopped. Make sure u back up your info (numbers, apps, all the stuff u wanna remember).
