Explorer.exe is not running in startup. If I start it using Task Manager it is coming and going. Please help me!
Hi hichris_4u
You should be able to replace the Explorer.exe. Type in the command prompt expand C:\I386\explorer.ex_ %systemroot%\explorer.exe This will expand a new copy to the windows directory.
You should also download a new version of SP2 and reinstall it. You also could download a clean copy of SP2 Click the Download button. The file is 266MB. Create a folder on the C:\ root called SP2 and download it there. Create another folder called SP2 files now at a command prompt type C:\SP2\WindowsXP-KB835935-SP2-ENU.exe /x it’ll ask you to specify an directory so point it to the SP2 Files folder and let it extract there. Now type in the command prompt expand C:\SP2 Files\I386\explorer.ex_ %systemroot%\explorer.exe to expand a new copy to the windows directory.
If you get an error on destination, try expand C:\SP2 Files\I386\explorer.ex_ c:\windows\explorer.exe
If you expanding fron the I386 from the C:\ root try expand C:\I386\explorer.ex_ c:\windows\explorer.exe
If all fails, try and download SP2 onto another machine and then burn it to a CD for install.
Good Luck,
Mark
SOURCE: Explorer.exe won't load
hi, your OS is corrupted and may need re-installation. Before that, if you can load explorer.exe manually and see the desktop, then go for a system restore from the system tools to an earlier date. Also try to boot to the known good configuration from the boot menu.
thanks
