I have a acer e21 speaker system 1 subwoofer and 2 small speakers.i wantto conneact it to the system where i can get the connection diagram
SOURCE: Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
SOURCE: acer m1118b speakers
go on acer.com and download the drivers install them and your speakers will start working
SOURCE: Only one speaker working - acer computer speakers
1 step: kindly check the connection of the left speaker if it is plugged to the right speaker properly.
2 step: Then check the balance under volume control if it has been set in the middle.
3 step: If possible check the speaker on some other device(cd player etc) other than your pc and see if the left speaker still doesn't have any sound.
if so kindly replace them
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
