I need an example of windows live id and password for vitua tennis 4 for pc windows 7 professional so that I can also save my game and achievements so please if anybody can help me so please help me
SOURCE: ask
keanne...
yap magcoconect na lahat iyong pre, pero pag ayaw try mo i-off ung firewall...siguraduhin mong may antivirus ka muna ok?
SOURCE: Good morning,
Remove adobe air. I am not sure what stands for acerVCM?
Windows live is usefull for manythings you need to keep this.Other then that I do not see any problem.
JMC
SOURCE: user password frozen
Try this,
1. Open a elevated command prompt.
Click on All Programs and Accessories, then right click on Command Prompt and click on Run as administrator.
2. To Enable the Hidden Built-In Administrator Account -
A) In the elevated command prompt, type
net user administrator /active:yes and press Enter.
3. To Disable the Hidden Built-In Administrator Account -
net user administrator /active:no and press Enter.
4. Close the elevated command prompt.
5. Log off, and you will now see the built-in Administrator account log on icon added (enabled) or removed (disabled) from the log on screen
SOURCE: i need the display driver for windows 7 for vgn-bx660p please. [email protected]
Have a look at this page that I've added a link for. The lower section has drivers for Vista which could work.
http://sonyvaiodriver.com/category/sony-vaio-vgn-bx660p-drivers/
Post back if no good.
SOURCE: FORGOT MY PASSWORD ON GATEWAY LAPTOP PC
Hi
You need to use the Password Recovery Tool to reset the password of your computer.
You need to view the complete steps. Click Here to Get the software and the Procedure.
In case if you have any trouble get back to us in Fixya.
Thank you
Nowadays more and more people like to create passwords on Windows 7 PC. In fact, a Windows 7 password is a good way to protect your precious computer data from unauthorized users. Unfortunately, you can be easily locked out of computer as the Windows passwords are easily to be forgotten or lost due to various reasons. In order to regain access to your locked computer and your precious data on it, you need to reset Windows 7 password.
You may forget to create a Windows 7 password reset disk, but resetting Windows 7 password on your own without reinstalling computer is still not a big problem. Just follow the below 4 steps, then you can reset Windows 7 password.
Step 1: Pick one good Windows password recovery tool
To reset Windows 7 password by yourself, you need to use good Window password recovery software. See if the software can reset lost or forgotten Windows password for your Windows 7.Most of the Windows password recovery software available in the market support password recovery for most popular Windows operating systems, like Windows 7/ Vista/XP.
Then, select the appropriate edition of the Windows password recovery tool to reset Windows 7 password. Generally speaking, Windows password recovery tool has 2 or 3 different editions to reset lost Windows password. Take Windows Password Recovery for example, it has 3 editions.
Its Standard edition allows you to burn a bootable CD/DVD to reset lost Windows administrator and user password for Windows 7/Vista/XP/2000/NT while its Professional edition allows you to burn a bootable CD/DVD or USB flash drive to reset Windows local password for Windows 7/Vista/XP/NT/ and Windows Server 2008/2003/2000. And Windows Password Recovery Enterprise enables you to burn a bootable CD/DVD or USB flash drive to reset Windows domain password and Windows local password for all poplar Windows OS.
Step 2: Prepare a PC with driver and a bootable CD/DVD or USB drive
As your PC is locked and you are not able to log on it, you need to find another available computer to download and install the Windows password recovery you choose to burn a bootable CD/DVD or USB flash drive to reset Windows 7 password. Please note the computer should have a driver. Both internal and external driver are Ok. Of course, the device - a bootable CD/DVD or USB flash drive- should also be prepared before starting to reset Windows 7 password.
Step 3: Burn a bootable CD/DVD or USB flash drive to reset Windows 7 password
Once you choose the right recovery tool and the device, you can begin to burn an ISO image file to the device to reset Windows 7 password. Here I take Windows Password Recovery Professional for an example to show you the whole process, which is really simple in fact.
First select to burn an ISO image file to CD/DVD or USB flash drive to reset Windows local password, then click Burn to start burning. Click Ok when the burning task is completed. It is very simple and just takes you a few seconds.
Step 4: Perform Windows 7 password reset with the burned CD/DVD or USB drive
When you have burned a CD/DVD or USB flash drive, you can reset Windows password simply with the burned CD/DVD. Insert the burned CD/DVD or USB flash drive in your locked computer and boot the locked PC from CD/DVD or USB. Then you can reset Windows 7 password under Windows PE. First choose the user name whose password you want to reset and click Reset button, and then click Ok to confirm and continue your operation. Click Ok when the password has been successfully reset.
With this Windows password recovery tool, you can rest lost password on Windows 7 in less than 5 minutes. Forgot Windows 7 password? Just try the steps above to reset Windows 7 password.
To reset your password, enter your Windows Live ID and the characters in the picture below.
Windows Live ID:
Example: [email protected]
Picture:
Type the 6 characters you see in the picture
Characters:
Select an option for resetting your password.
Email me a reset link
We'll send another password reset link to these email addresses.
js*****@yahoo.co.in
Customer supportpress one among this and then press next,if you have provided alternate e-mail id at the time of opening account you will get a link to reset your password or you need to press customer support
