Starting the SBG900 Setup Program
1. On a computer wired to the SBG900 over Ethernet or USB, open a Web browser. Do not attempt to configure
the SBG900 over a wireless connection.
2. In the Address or Location field, type http://192.168.100.1 or http://192.168.0.1 and press ENTER to display
the Log In window:
3. In the User ID field, type the User Name; the default is "admin" (this field is case sensitive).
4. In the Password field, type the Password; the default is "motorola" (this field is case sensitive).
5. Click Log In to display the SBG900 user configuration and status windows:
6. Then click on "Gateway" located at the left corner.
7. Then click on "Port Triggers".
8. Then choose "custom"
And from there:
ADD NEW SPECIALAPPLICATIONName Enter the unique name for the port trigger. This is typically the protocol.
Enable Select this box to enable the custom port trigger.
Protocol Sets the transport protocol for the port trigger - TCP or UDP.
Port Range Sets the port range for the port trigger. Type the start of the range in the
(From:To) left field and the end in the right field.
Session Chaining Enable session chaining if the application needs to open one or more ports in
different ranges to operate properly. The options are Disable, TCP, TCP/UDP.
Session Interval Sets the session interval for the application:
• If the port triggers detect traffic on the Port Range within the Session
Interval, it is considered to be related to the initial session.
• If the port triggers detect traffic on the Port Range after the Session Interval
expires, it is considered to be a new and unique session.
Address Replace Sets the address replacement method for the application.
Multi Host Select if appropriate for the application.
Add Click to add the port trigger to the PORT TRIGGERS TABLE.
PORT TRIGGERS TABLE Lists all port triggers you defined and their parameters.
Hope it help you....
