Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
alan Posted on Jun 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Delete pop up
Hp audio/volume pop up in centre of monitor screen, win7
Shaik Shaksha
Level 2:
New Friend:
  • Expert 29 Answers
  • Posted on Feb 03, 2015
Shaik Shaksha
Expert
Level 2:
New Friend:
Answers
29
Questions
0
Helped
6507
Points
101
Go task manager by pressing "ctrl+alt+del" then go to applications and select hp\pop up end process -task
MY PROBLEM IS MY LAPTOP IS HP MY WIN7 IS NOT HAVE SOUND SYSTEM PLS HELP ME
You need to go the HP support website and download the audio driver for your computer.
Also it may be worth checking to see if the volume hasn't been muted or turned right down. Click on the Volume control icon that looks like a speaker in the bottom right hand corner of the screen.
How do i remove the volume icon from keep popping up onto screen
when the volume icon is pops onto your screen right click on it select delete also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
1helpful
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
Sounds like one of the buttons on the monitor is sticking physically. Try:
  • checking the buttons for dirt that might be holding it in
  • cleaning the buttons with a soft brush
1helpful
2answers
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
2helpful
The Volume Screen on my monitor keeps popping up
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
